Hi Guys,
Just looking for some feedback on the closing of my pool. I’m a new pool owner so this is the first time I’ve closed a pool. I’m a plumber.
Jets - Made up a piece of pipe that I can screw into my jets. This extends above the water level. I blew these out with air, poured in some antifreeze and then capped
Skimmer - I have a combo skimmer. I made a piece of pipe with a valve. I used this to blow out my main drain and then closed the valve to create an air lock. I blew out the suction line from my pump and then poured in some antifreeze and plugged that hole with a screw type plug. I then used a sponge to remove all the water from my skimmer. Then I put a pool noodle in my skimmer box and filled the box half way with antifreeze.
Anything I should have done differently?
