I want to make sure I've got all the steps right before I start. Any tips or suggestions would be greatly appreciated!
• Clean and shock pool
• Backwash and rinse filter
• Drain pool 4” below returns.
• Attach air compressor on pump drain port. (Do I keep the main drain open or partially/fully close?)
• Blow out lines until no water is coming out at all.
• Screw in skimmer Gizmo and plug returns.
• Close main drain?!?!
• Remove drain plug on filter and remove air compressor. Place plugs in pump basket for storage.
• Cover pool.
When do I close the main drain or do I need to? Do I need to add antifreeze or any other chemicals? Am I forgetting anything?
What air compressor attachment do I need. I know think one side should be a threaded ¼” or ½” (I have a standard Hayward pump)? The other side I’m assuming needs to match the coupling system I have for my air compressor hose. Can I find this attachment at Lowe’s or home Depot?
A few more details about my pool. All of my equipment is indoors. I have two valves before the pump. One for main drain and one for the skimmer. I have a hole in my liner at the bottom of the shallow end. It's been patched but if anything touches it it bubbles so I know the patch isn't very secure. Doesn't leak on it's own though. Thanks everyone!!!
• Cover pool.
