We have a 27k gallon plaster pool. It was newly built and filled around March 15th. It has a cover which is closed probably 75% of the time. It has a SWG.
I ordered the TF100 kit and here are my results
PH 7.8
FC 13.0
CC 0-0.5
CH 400
TA 390
Our pool is filled from our well which I know has high alkalinity.
Since the test I have added two quarts of Muriatic acid (31%) and turned off the salt cell and opened up the cover to let the sun take down the chlorine.
About four days before the test I added three gallons of acid over the course of two days to get the PH down to where it is now.
The water is crystal clear and swimming causes no irritation to us even with the high chlorine. I was only testing just to see where we were not because of a problem.
I guess my questions are what should I do from here? Turn the salt cell down and keep adding acid? The high FC and TA are my main concerns.
PH 7.8
FC 13.0
CC 0-0.5
CH 400
TA 390
