started up NEW pool one week ago - have been using test strips until tonight
Water look great clear and sparkle
below are readings
FC - 7 - goal tweak salt cell down or pump run time down in next week after further testing
CC - 0 - mantain
PH - 7.8 - lower PH to lower TA?? suggestions??
TA - 160 - goal 60 to 80 see above on PH comment
CH - 250 - mantain
CYA - 20 - raise slowly to 70 - add approximate 70 oz of stabilizer in next couple of days through sock
Salt -3600 - maintain - this is Pentair recommendation
Borate - 0 - goal is 50 bought 25 pounds of Boric Acid to add to pool after get other numbers in line
water temp - 70 degrees
SW cell set at 50% - monitor and reduce pump run time or reduce setting to 40%
Pump
1900 RPM 22 hours
3250 RPM 2 hours
goal - reduce run time and low speed RPM BUT maintain enough flow for salt cell and heat pump - suggestions?
I like the two hours at high speed to get a good skim early 7:00 - 8:00 AM and at 4:30 -5:30 PM before night swim lots of leaves and pollen
In addition to lots of brushing side and floor - have ran robot cleaner three times in week one and pool is pretty clean
Open to thoughts and suggestion
Thanks for a great website!!!
below are readings
CC - 0 - mantain
CH - 250 - mantain
Pump
1900 RPM 22 hours
3250 RPM 2 hours
