Hello everyone,
I recently moved to a new home with a combined pool/spa, where the spa overflows into the pool. While my previous home had a pool, I admittedly was not the most diligent in its maintenance and primarily relied on test results from my local pool store. However, I promised myself I would be more diligent in caring for this pool. To that end, I recently purchased and received the TF-PRO SALT with SmartStir, and fumbled through my first set of tests today. While the included instructions were easy to follow, I definitely get the impression that there is a bit of a learning curve in reading other members' posts who are just getting started, and from my own initial experience.
Having said that, I'd like to share my first test results with some questions/comments and get any feedback as to how to proceed. Thanks in advance!
Link to results from 1st tests
Other notes
Thanks!
- Chlorine & pH test - Both of the results were darker than the top of the range. Thus for the pH, I listed my result as 8.2. For the chlorine test, I also did the Chlorine Drop Test to get the 7.5 result.
- Total Alkalinity test - I was a bit surprised by this result as when I had the water tested at the local pool store it reported the TA around 230. Not sure if this is a them or me issue.
- Calcium Hardness test - This result was in line with the number reported by the local pool store. As a result, they recommended I add a quart of Salinity Stain Control. I passed on the recommendation.
- CYA test - This is one of the tests that I felt was a bit challenging as I felt that no matter how full the "CYA View Tube" was, I could still faintly make out the black dot. As a result, my value of 40 may be a bit high?
- Salt Test - My IntelliChlor current reads 3450ppm which seems to track with the value from my test
- CSI - From what I've been reading on the forum I should be okay with a value between -0.6 and +0.6. Assuming this value is correct given it's based on the accuracy of all my inputs, I'm thinking perhaps I was correct in passing on the Salinity Stain Control.
Other notes
- Current pump schedule is daily from 9am - 8pm (2100 RPM with the IntelliChlor output set at 65% for the pool and 0% for the spa).
- There is a high-speed schedule that runs from 1pm - 5pm so the vacuum (Pentair Rebel) can do some cleaning.
- Pool is enclosed in a screened cage so very little in terms of large debris makes it inside the pool
Thanks!
