Hi guys,
complete novice here, I "inherited" a pool last winter and are doing most things for the first time. The pool was fine last summer, and we uncovered everything two weeks ago.
Unfortunately, the pool is light green throughout, the sides and the bottom are not slimy and don't seem to have a lot of algae on them. So, I think it's time to SLAM.
The liquid chlorine (13%) is on its way and I wanted to double-check with you guys, whether I understood everything correctly.
Here are some quick numbers/parameters:
I am located in Germany, and I would be thankful, if you could name a few trustworthy online shops for pool test kits, chemicals etc., if you know of any.
Thanks for your help.
zyl
- 22.000l overground pool / 4839,324 gallons
- Sand filter pump (a year old), with a capacity of 8m³/h, set to run for 6h/day when the water is clear
- ph is at 7.2 (steady for the past two weeks).
- DPD show that CL (CC?) is between 0,3 - 0,6mg/l as of yesterday (tested with this kind of test: link to picture)
- CYA is at 50
- Which makes my slam level 20 - does that mean maintain FC levels of 20? I only have the above test, is there any way I can calculate the right FC levels.
zyl
