Hey all. I've been doing a lot of reading, and I am confident I can open my pool solo this summer. I'm in year 3 of ownership, and live in the Clemmons, North Carolina area. We have fairly mild winters with around an 8" frost line however I still chose to have a solid safety cover installed. This will be the first year I've been involved in any form of opening it (and closing it hopefully this fall). Before I jump right into getting it running again, I wanted to understand what was done to close it so I can be successful this fall. It seems that something was done differently between the builder (Year 1) and the pool company I had close it last year (Year 2). I'm not sure if what the pool company did to close it was acceptable or not. For starters the water line appears high. I can't tell for sure as I have not removed the solid cover yet, but peeking in the gap near my waterfall, I can see its very close to the top. I also found the return jet caps sitting in my waterfall pump's basket. So I presume my lines were not blown out - I had asked for this to be done. Which makes me also then question if my deck jets or waterfall were blown out. Those seem to be the most important parts to have been blown out since the plumbing is so close to the surface. *edit* also not clear on what he did to the main drain and skimmer lines. I have a plastic tube in the skimmer box for ice compression, however the jandy valve was set to open. so there was no airlock.
So that said...
1) Do I need to blow the waterfall and deck jet lines out? The pool builder did it in the original year.
2) How do I blow these out. I don't see an connection point to do so without running through the sand filter and water heater. Is it possible to do this? Is this why the lines were not blown out?
3) Do I need to blow out the return lines and main drain for my area?
There is also a connection point labelled with a "?". I'm not sure exactly where it ties in at. The builder had to add a second pump as the original pump wasn't enough. so he modified the plumbing to add that pump. it is either tied to the Skimmer or the Main Drain. I do not know which. There is a backflow valve on it to prevent water from rushing back into it when the waterfall is not in use. Probably not relevant to this discussion, but I am going to mention it anyway.
Thanks for your help.
So that said...
