Just finished our first pool. Fill date was Nov 17. Up to now the PB has been handling the water testing and maint. but now I'm on my own so I just completed my first full test using my new TF100 kit. Hopefully I did everything correctly. Here are my readings...
PH 8
FC 4
CC 0
TC 4
CH 400
TA 100
CYA <20 (Note: I have not added CYA and I'm not sure if the PB did at start up so this number seems like it might be suspect?)
After reading the various info here, it looks like the PH and the TA are a bit high but I'd love any feedback from folks more experienced than myself. PB info says to add 1-2 cups of muratic acid to lower the PH, is this correct? Also, do I need to add CYA during the winter months? The chlorine levels have been fairly steady over the past week or so. I'm in North Florida. Air temp during my tests today was about 52. Water temp 64 which is about where it's been since right after it was filled. Pretty sure it ain't getting any warmer until spring
Looking forward to learning more but in the meantime any advice is appreciated. Thanks.
PH 8
FC 4
CC 0
TC 4
CH 400
TA 100
