Opened my pool a few days ago and added chlorine. Today I got around to doing a full test.
FC 14
pH 7.3 (somewhere between 7.2 and 7.5)
TA 50
CH 50
CYA 30
Salt 1800
Clearly I need to add stabilizer. I'll get on that first. I'll probably also get some salt in there. Not sure what to do about the pH. It stayed in the very low 7's all year - never naturally increased. I might add something to bring that up a bit this year. I'll have to read up on that because I believe it impacts alkalinity. First thing's first - to the store for CYA and Salt.
Second issue is a question about salt. My SWG says salt is 2900 and my test says 1800. I try to keep it around 3000 so no doubt I'll put in a bag, maybe two. Question is, does it matter? If the unit thinks it's at 2900, isn't that all that matters? Won't it still keep making chlorine as long as there is actually salt in the water, rather than be 2900 per the unit, or 1800 per my test kit? BTW, my test kit for salt is a 3 or 4 years old. It's always read different from the unit, but would it be worth getting a new test kit, or, basically rely on the unit and put in more salt based on that.
FC 14
TA 50
CH 50
CYA 30
Salt 1800
