- Jun 9, 2015
- 62
- Vinyl
- Liquid Chlorine
- CircuPool Edge-40
PoolMath Logs
troublefreepool.com
So after I get this settled what is the most important to check daily and weekly?
Always start on the low side and work your way up, you can always put more, but you can't take it out very easily. That being said, 4200 isn't too high, especially for a new SWCG. I would just keep an eye on the SWCG and make sure it isn't complaining about too high of salt content.I tested the salt level the other day and it was low and the pool math suggested I add a couple more bags and now I’m over the recommended level for salt
It will help a little bit, especially if they are jumping in the pool a lot, but I doubt it'll compare to a fountain or such thing. I assume you want to aerate so you can get the TA down? 100ppm isn't too bad, I wouldn't worry about it, just keep your pH in check and over time the TA will probably go down on it's own.Also to aerate my pool; would kids swimming around help?
It'll take some time to get to know what your pool needs. You want to check FC and the pH daily for a while. Once you get to know your pool you might be able to check those less often. Check the TA and CH weekly, and keep an eye on your CSI. Keeping your CSI within range will extend the life of your SWCG. You can look at this link for more info: Basic Pool Care Schedule - Trouble Free PoolSo after I get this settled what is the most important to check daily and weekly?
Yes I have the Taylor k-1766 kit. I checked it twice. I may have messed up cause my kids were next to me splashing and talking in the pool. I went ahead turned off the swg.Did you add more salt...11,000 ppm? Unless you had a truckload of salt delivered, it's probably a testing error.
Shutdown you SWG for now and let the FC drift to down to the target FC for your CYA.
Retest the salt level. Are you using the Taylor K-1766 salt test kit?
Are you using a Speed Stir, or the TFTestkit equivalent? As a newbie, my testing accuracy was dramatically improved once I got one. Worth every penny, especially on the salt test.Yes I have the Taylor k-1766 kit. I checked it twice. I may have messed up cause my kids were next to me splashing and talking in the pool. I went ahead turned off the swg.
I can only guess, but I bet you used a 25 mL sample as opposed to 10 mL. The instructions are bit confusing as they direct you to, "Rinse and fill 25 mL sample tube (#9198) to 10 mL mark."Yes I have the Taylor k-1766 kit. I checked it twice. I may have messed up cause my kids were next to me splashing and talking in the pool. I went ahead turned off the swg.
I used a speed stir.Are you using a Speed Stir, or the TFTestkit equivalent? As a newbie, my testing accuracy was dramatically improved once I got one. Worth every penny, especially on the salt test.
Nothing.How many bags of salt did you add between 4k and 11k ppm?
That might be it. I used the container that comes in the box but I might have went to 25ml instead of 10ml. I’ll re-check this morning while it’s quiet.I can only guess, but I bet you used a 25 mL sample as opposed to 10 mL. The instructions are bit confusing as they direct you to, "Rinse and fill 25 mL sample tube (#9198) to 10 mL mark."
The test is a bit different than other titration tests. Most require you to continue adding drops until there is no color change. The salt test directions read, "Do not add enough R-0718 Silver Nitrate Reagent to give a brown color. First change from yellow to a milky salmon (brick red) is the endpoint." With each drop valued at 200 ppm, you can really skew your results chasing that brown color change.
My vote as well. The instructions state : fill 25ml vial *our brains shut off and stop reading* to 10ml. You either screwed it up, or are way smarter than most of us.That might be it. I used the container that comes in the box but I might have went to 25ml instead of 10ml.
Other things to consider:At the 100% setting, your SWG should produce 0.4 ppm of FC each hour. Running 10 hours at 100% should raise your FC by 4.0 ppm daily. That's probably more than you'll need, but you can reduce runtime or percentage from there.
