- Jun 1, 2018
- 16,080
- Vinyl
- Hayward Aqua Rite (T-15)
Sadly, An overnight loss of over 1ppm is a fail -The FC went from 9 at night to 7,5 in the morning.
You have organics (algae) brewing.
This requires the SLAM Process which is impractical at your current cya level (160)
You need to exchange at least 75% of your water to get cya down to around 40 so your slam level is 16ppm - much easier to maintain than the current necessary slam level of 64ppm. FC/CYA Levels
The no drain water exchange outlined in the draining article I posted above is the safest option for replacing that much water especially with all the tile.
