Look what turned up the other day....
Look what turned up in sunny Zimbabwe!!! by pommezimbo, on Flickr
Should keep me going for a while
BIG shout out to a certain AWESOME member of this site for making this happen!!!!! You know who you are!!!!!
First REAL numbers. (not from strips/ HTH "sort of" reliable 3 way drop based kit)
FC-6.5
CC-0
CH 130
TA 60 (HTH says 80, I wiped with a damp cloth each time as directed)
PH 7.5
CYA 30
Borates 50-80 (looked in between these on strips)
SO, recommendations? :-D
The pool is concrete shell about 15" thick and then all of surface tiled as in pic.
The dot for CYA was JUST visible at the 30 mark. Completely gone at 40. It was a very bright sunny day and time was about 1.30pm.
I mixed the solution by putting the magnet pill in the mixing bottle and using the speed stir.
As always thanks in advance!!!!!
If u wanna know more about my situation and what I have done so far with this pool, or the challenges I have faced sorting out the pool in this 3rd world country see thishttp://www.troublefreepool.com/no-way-to-obtain-fas-dpd-test-t71335.html post.
FC-6.5
CC-0
CH 130
PH 7.5
CYA 30
