Right on schedule, my three year-old desert pool will be due for a full drain/refill this Fall (CH is 725 and rising). Any ideas for some "While you're at it..." jobs would be most appreciated. I will already be using the opportunity to give the tiles a good scrubbing, but is there anything related to the pebble sheen that can/should only be done when the pool is dry (some sort of deep cleaning, etc?) I do have a couple small rough spots in the pebble sheen where it appears a small piece came loose when the pool was new....any recommendations on how best to spot-patch these areas? I'll also pop out all the IFC heads and spa jets, as well as remove the floor drain cover for a good inspection/cleaning.
Also any gotchas to watch out for in the drain/refill process itself? I was just planning on renting a sump pump and sending the water down our house plumbing cleanout in the front yard.
What else ya got?![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
What else ya got?
