Hey guys, lovely 3 year old swg pool received it's first pool test kit (and not the strips). I took two readings so here are the numbers
Test #1 which i'im not sure if i did it right
pH > 8
FC 1.4
CC 0
TA 90
CYA : not sure if I ran the test correctly. I could see the dot all the way down if I just looked right.
Between test, i added bleach 12% and muriatic acid in quantities based off the pool calculator.
Test #2 (about an hour a half later)
pH 7.6
FC 3.2
CC 0.0
TA 110
CYA: Stilll not sure how to run the test appropriately. I can still see a bit of the black dot when the container is full of water.
ANyways, what's my start! Water currently is clear. FLoor and walls looks drity (mustard algae?)
pH > 8
FC 1.4
CC 0
TA 90
pH 7.6
FC 3.2
CC 0.0
TA 110
