finding replacement skimmer [solved]
pmh3986
Active member
Aug 1, 2024
34
Western NY
[solved: see last edit]
I need to replace the skimmer on my old hybrid pool (fiberglass walls).
The original has a marking 8655-32, and googling that seems to bring up Sta-Rite U-3. The U-3 specs show an opening that's a bit smaller than what I have (7-5/8" x 5-5/8" whereas the opening in the wall of my pool is 8-11/16" x 5-15/16".
If I can find something with a slightly larger opening than what I have, I can cut a new opening and drill new holes.
Does anybody here have any reference links to a list of skimmer faceplates with dimensions called out from the popular brands? or other insights to help me find a suitable replacement?
edit: I did find one that fits this criteria, but it's made of ABS and is a brand I've never heard of (which isn't saying much):
edit 2: Jacuzzi PMT has an almost identical opening, but different hole placement. I can't seem to find that for sale anywhere.
edit 3: I had been assuming that the listed inside dimensions of the faceplate would match exactly the hole size cut into the wall, but when I looked deeper into some of the installation manuals, realized many face plates overlap the throat a bit, and this opened up some more options for my particular situation. I ended up getting a Waterway Renegade
Thanks!
Thanks!
Waterco/Baker Hydro has been around a very long time. Most modern skimmers are made from ABS, that U-3 is.
Thanks. Glad to hear they have been around, I just wasn't finding much in the way of "reviews" about them, and the photo in the amazon link had a big sticker "made in malaysia" so I wasn't sure if that was a red flag for some piece of junk that would crumble in the ground.
For ABS to PVC connection, I'd probably have to use a threaded connection?
