finding pool volume?
Estimating Pool Water Gallons
If you need to get an estimate of the amount of water in your pool you can use the calculator at the bottom of the old Pool math web page. You simply enter the pool dimensions and average depth and it gives you the gallons of water in the pool.
Pentair has a Pool Volume Calculator that lets you select from rectangular, oblong, round, and triangle shapes.
There is also a Chemical Way of Calculating Pool Volume using an alkalinity test kit, sodium bicarbonate or acid, and the formula.
Reactions: scout123
