Pool was recently refilled with (very hard) well water (long story). When I got back last week, “pool guy” said he “balanced and conditioned” it. I checked the chemistry Friday morning & got these numbers:
TA 220
CH 170
PH: 7.6
FC 3.5
CC 0
CYA: <20
I’ve been checking it daily & adding liquid chlorine and MA as needed. Tonight’s numbers looked like this:
TA: 230
CH: 275
PH: 8+
FC: 2
CC: .5
CYA: >20, <30
Not sure if the TA/CH variations were my imprecision or actual changes. The PH definitely is spiking between treatments.
The pool’s uncovered in full sun and it was over 100 out today. Water temp is around 80.
Pool guy insists that “everybody” uses “tablets” here because of the hard water. But that route led to sky high CYA levels a few years back and a mess. (And then I found y’all at TFP…)
Since the CYA levels are still pretty low, using the tablets in the chlorinator and float for now doesn’t seem unreasonable, and should help push down the PH, right?
Will using Trichlor tablets in the chlorinator & float affect the CH?
Is it just a matter of having to keep adding acid until it comes into some sort of equilibrium?
Are there other things I can/should do to keep things from going South? Things that I should definitely *avoid* doing? (Other than adding Cal Hypo--that is clearly *not* what it needs.)
I was supposed to be done with this house and this pool and my primary concern is keeping it looking good until it’s sold (with the minimum amount of time and $$). But being able to swim takes a bit of the sting out of having to deal with it. ;-)
TA 220
CH 170
PH: 7.6
FC 3.5
CC 0
CYA: <20
TA: 230
CH: 275
PH: 8+
FC: 2
CC: .5
CYA: >20, <30
