- Jul 15, 2012
- 632
- Plaster
- Hayward Aqua Rite (T-15)
My pool pump sucks from a 4 -way split with individual levers to turn each off (main drain and 3 skimmers). I blow my cyclone with main drain valve open and the three skimmers closed, then after blowing for a bit, close off the main drain to seal. But then do I leave the valves for the skimmers open or closed when I pour in the antifreeze from the skimmers? I cannot remember what I have done the last 3 years. Does it matter? I think I want them open so the anti freeze can get into the pipes without an air lock, but then do I close afterwards? I know to insert gizmo and noodles in skimmer after pouring in the anti freeze, but I am unsure what is best procedure on the other end by the pump-side pipe. East leave valve open or closed for winter - whatever is best.
Thanks
Thanks
