I have previously drained and refilled my pool to get my CYA levels which were off the charts(300+), under control. My area has hard water, and after refilling the pool my CH was very high (625).
I was wondering if I could take my sump pump and connect it to something like this and run it for a while, returning the filtered water back to the pool.
Hydro Life Camco XL Pool and Spa Calcium Block Filter - Specifically Designed to Reduce Calcium Levels and Heavy Metals in Source Water - Filters Up to 40,000 Gallons of Water (52812) https://www.amazon.com/dp/B0839VJNZT/ref=cm_sw_r_cp_api_glt_fabc_G51AMY739E5JGVAZ79Y3
I figure that this might filter chlorine and CYA so I would need to stay on top of that.
As the subject line suggests, tell me why this is a dumb idea.
Thanks!
Thanks!
