Hello, I have a vary typical setup on my inground - Hayward Vari-flo XL valve and a S244T sand filter. All has been great for past 7 seasons. This open is a bit challenging. All came up good, backwashed, rinsed and put back in operation. Woke up this morning and noticed a drop from mid skimmer to bottom of skimmer. I went to filter and noticed the clear section of the backwash line was showing some low flow. Sure enough, I went to the back of the shed where the backwash hose is located, and there was flow. Thinking things may be stuck, I shut down, spun the handle back to backwash, then to rinse, then to filter and tried again. Same thing. I then shut down and the flow still continued in more of a siphon mode. Obviously something is stuck open, but unsure if it is addressable by a repair of the valve, or if it is needing replacement, or am I way off on diagnosis.
Thanks!
Thanks!
