I'm a bit confused...pool store numbers are reading different than my Taylor FAS kit.
Pool store says:
FC -5.87
TC-11.02
pH-7.1
TA-93* has been adjusted due to the effect of CYA on test TA
CYA-68
My home test kit says:
FC-12
CC-0
pH-8.0
TA-120
CYA-didn't test
The water is crystal clear and blue, but the heater is running Lo after backwashing 2 days ago. The pressure was at 9 after backwashing and is now at 11, which I don't think is high enough to need another backwash, except I don't know why the heater would be running Lo.
Why would the pool store numbers be so far off my own numbers? Test kit is brand new, so nothing is expired.
Thoughts? Thank you!
Pool store says:
FC -5.87
TC-11.02
pH-7.1
CYA-68
FC-12
CC-0
pH-8.0
TA-120
CYA-didn't test
