I'd like to drain and refill my pool in the near future. I am not sure the last time it has been done but most likely quite some time ago. I will power wash the calcium line while it is empty. My question is regarding the need to replace the cartridge in the filter during this time. The cyanuric acid is very high and I was told that it tends to bind to the filter so it should be replaced as well. I'd really like to avoid this as the cartridge is less than 6 months old and hundreds of dollars (system 3).
Is it usually best to replace the filter when the water is replaced in the pool?
