Hello. I have a coleman 18 ft x 48 above ground pool.
In regards to the pump that came with it. I'm having a hard time keeping the water clear. I'm wondering if the pump is doing its job. How do I know?
The motor runs, there is water above the inlets inside the pool.
When I look at the hoses connected to pool does all hoses supposed to be filled solid with water? Because i see not all hoses are filled solidly with water.
I don't know if the pool water is circulating.
Thank you ..
Thank you ..
