Hello all,
I've finally gotten to the "switch on the equipment" phase of the operation. Last fall I had a local company close the pool. They blew out the lines, turned off the equipment, removed the drain plugs, and put rubber plugs in the skimmer and the returns.
Today I pulled the rubber plugs, reinstalled the drain plugs, screwed the pressure gauge back in, opened the valves leading from the skimmer and main, primed the pump, opened the air release on the filter top, and switched it all on. Once the air all got pushed out, everything seemed to be running normally...except my PSI keeps dropping. So I reopen the air release, let some air out, close it, and it will go back up (it might also go back up on its own), and the pressure returns to normal for a few moments. Then the process repeats.
What gives? The pump doesn't seem to be having any trouble drawing water, through the amount going into the filter basket does drop when the PSI drops. IS it normal to have to play with it for a while before all the air is fully out of the system?
