Hello everybody,
im seeing a lot of good threads here but unfortunately, i could find one discussing my issue. I was wondering if someone could help me out or had some advice.
I have a broken Filter Valve (the spring inside broke, it was very old) and i replaced it 5 days ago.
5 days ago, water was clear and nice, now is all cloudy, very cloudy.
Pressure when in FILTER, is around 20psi; if i change it to Waste, it goes down to 0 but water come out fast and good (no issues here).
However, if i change to Backwash or Rinse, the water starts getting out at 20% what it used to be.
I opened the FilterValve and is all good (it was new but who knows right?). When i changed the Valve, i remove some dirt from the top of the filter. Could it be i drop some sand inside the filter line? i dont remember doing it but it could had been that?
No air leaks or water dripping, no sand inside the pool.
Chlorine is normal, PH is a bit higher than it should (which i'll reduce).
Any help would be really appreciated.
