Tested yesterday, here are results:
FC 6.0
pH 7.5
TA 70
CH did not test
CYA 60-70
I added acid two days ago, so pH is good, but it will rise....always does here.
Yesterday I tested my city water and possibly discovered one of the reasons why...pH was about 8.0 in tap water....so, when I add water to pool, I'm adding high pH water.
TA at 70 is a bit low, right? If I raise it, will it help me keep pH more steady? Suggestions on level for TA knowing pH is a constant fight?
I also added 64oz of 10% liquid chlorine assuming the CYA is actually 70.
Thoughts?
FC 6.0
pH 7.5
TA 70
CH did not test
CYA 60-70
Thoughts?
