We recently had a fiberglass pool installed. I was curious of the install as I'm in construction too and had watched a bunch of pool install videos just to attempt to partially educate myself on whats "normal" but there were no install videos of fiberglass Pools in sand in high water table areas. The install went pretty much like the videos but they required 6 posts 3 on each side to be installed under the pool lip to keep the pool level whilst filing with water and back wash sand around the pool. Now the back washing def compacted the sand nicely around the pool as it was filling but the support posts don't get cut off and are left in place. My concern is that the lounge deck on the shallow end of the pool is not an easy place to get the sand to wash under but it feels mostly solid but the shallow end is about 1/2" higher than the deep end due to the weight of the water in the deep end making the pool sink a little more. First off what's an acceptable amount of out of level between the 2 long ends and would it be a good idea to cut these temp wooden support posts out in case they cause issues in the future with the pool settling?
