I am having to add water to my pool daily to keep the water level half way up the skimmer. I did a bucket test for 24 hours, running my pool normally, and I lost approximately 1/2" of water total. (With the pump on 12 hours during the day, I lost about 1/4" and with the pump off 12 hours at night, I lost another 1/4." I lost about 1/8" inside the bucket to evaporation with the pump on, and nothing to evaporation with the pump off since it was at night.) I checked the pool equipment during the bucket test, and noticed that the ground around the pump stays wet when the pump is off, but the ground stays dry when the pump is running. If I put my hand underneath the pump when it is off, I can feel it slowly drip, but I don't feel any water coming out when it is running. After being off for 12 hours, the ground around the pump was pretty wet but there were no puddles. I see no bubbles in the pump basket or out of the returns when the pump is running so it appears to be working normally. I was told by a pool pro that it sounds like the seal in the pump could be leaking, which wouldn't surprise me since this is an older pump. Could this be the source of my leak, even though I'm experiencing a little bit of water loss with the pump running and I see no evidence of any leaking around the pump when it runs? Or does it sound like there could be a leak in the shell of the pool somewhere since I lose about the same amount of water with the pump on as with the pump off? I checked the backwash line and I'm not losing any water out there right now, so the only place I see any evidence of leaking around the equipment end is around the pump but only when it is off. I realize that 1/2" a day isn't a significant amount, but it concerns me because I know that leaks can cause problems if they aren't fixed in a timely manner.
