Hi everyone... thanks again for all the great input I have received. I just wanted to give a couple updates on my troubleshooting. Forgive me if I already mentioned it, but I did turn off the main breaker to our house and was still able to feel the current. Last night I bought a 6-ft piece of #6 copper wire and put one end in the water and the other up on the wet concrete pool deck with a heavy brick on it just to see if it would make a difference if the potential was different between the two. I was still able to feel the current with it in place.
Another thing I noticed which I thought was odd is that I can only feel the current on one side of the pool. As a test, I got in the pool, stood at the shallow end by one of the step rails and began working my way down the length of the pool touching the wet concrete deck with my fingers. I had a slight cut/abrasion on my finger which made it quite noticeable and made it easy to test. I felt the current all the way down that long side of the pool, but just after I made the 90 degree turn down at the deep end, it was no longer there. I continued across the deep end and then all the way back down the other long side, and felt nothing. As soon as I got back to my starting point, it was back. So basically, I could touch the deck a few inches to the right of the step rail and feel nothing and then touch a few inches to the left and feel it. I have no idea why it's not consistent all the way around the pool. I also called a different electrician in town that wasn't the guy that my pool guy uses, but who does all the electrical for another big pool company in town. He asked if I had a separate electrical panel at the pool equipment pad. I told him no because they wired it straight from my breaker box in the garage into the pump and timer for the SWG. There is no additional panel at the pad. He thought that perhaps voltage was leaking into the pool since there wasn't that additional panel.
