I’ve read that since the swg stops working around 52 degrees, that you should treat the pool with liquid chlorine during the winter months. My question is, once I start using liquid chlorine, should I use the cya/fc chart as if I’m using bleach as my sanitizer? Cya requirements for salt is a good bit higher, so I would have to drain a bunch out to get down to bleach sanitizer cya requirements, correct? Or should I always just proceed using the chart for swg during winter even though I’m not using it?
