For weeks, I've been maintaining FC levels between roughly 3-7ppm as my CYA has shifted from 50 to 40. Suddenly this evening, I'm attempting to run the FAS-DPD and after adding the 870 powder I am adding 20-25 drops of 871 and the 10mL solution is still remaining a dark pink. Is this a sign that my reagents are suddenly expired...I just can't make sense of this sudden change.
It hasn't been a year since I purchased the TF-Pro kit however I am nearly at the bottom of the 870 powder. Does the fine dust that settles at the bottom sometimes give false readings for any reason?
Thank you!
Thank you!
