I have a 12*22 oval Bestway vinyl pool (approx 6k gallons) that I've been running with a SWG since April (I have the smaller SWG, I know, mistake I should have gotten the bigger one but nothing was in stock earlier this year so it is what it is now). Pool gets a lot of direct sunlight basically all day and ambient temps have been over 100F for several weeks with pool water frequently at 89F. Being new to pool maintenance I'm struggling with several things.
Lately I've been struggling to get detectable FC levels using a FAS-DPD test and my pool water is getting cloudy and I can see some algae growing on the walls. I tried to get my CYA up to about 75ppm to follow TFP advice but things seemed to go south when I did. That's when I can't get any pink when I add the 2 dippers of R-870 powder. If I then try to test for CC, typically I won't get much if any pink when I add the 5 drops of R-003 but if I leave my Taylor SpeedStir running while I log my test results, I finally turns pink. If I add the 871 test reagent, the water turns clear again. If I leave the SpeedStir running, it will again turn pink, I can add another drop of 871 and it will clear. I give up after about 3 repetitions of this meaning I'm either at .6 CC or 1.5 CC depending if I'm testing at .2 or .5 FC.
What does this mean? Do I have more CYA than I think I do and the CYA slows down the test results? Should I just do the test once until it clears and stop letting it continue to stir after I'm done?
When I test CYA using my Taylor 2006 kit I'm trying to make the dot totally disappear. I have good vision so it takes a lot of test liquid for the dot to become obscured. There is a point where the dot gets harder to see and stays about the same until I really fill to get it to disappear. Is this first "harder to see" the limit I should stop at? I confirmed my results by doing a 50/50 mix of pool water and filtered tap water and got within 10ppm (80 with just pool water and 70 with 50/50 mix). Filled the pool and tested again and now I'm testing at 50 CYA.
Anyway, I am trying to SLAM now to clear the water, I added 1 gallon of HDX Liquid Chlorinator (10% chlorine) and I waited about an hour or two to let the water circulate and tested with FAS-DPD and that's when I registered 4.5 FC. The "effects of adding" in the app makes me believe that my FC should be above 17PPM with the addition of bleach.
Help, what am I doing wrong? If it was algae bloom wouldn't I see a lot of CC? Or is the fact that my liquid keeps turning pink indicative of high CC? Why the delay on turning pink after adding the R-003 drops?
Perhaps I don't have as much CYA as I think I do? When I first added CYA and got it to 30ppm, the SWG was more effective and I was frequently testing 3ppm FC (before the extreme temps though).
