Good morning everyone. I am just posting to confirm that which I have read through various posts.
I have a Hayward T-15 swimpureplus. The serial number says it was made in 2016, however installed 04/17.
This season, I am getting notoriously lower salt readings from the controller. I know not to trust their "estimate number" rather have tested my water with salt strips at 3400ppm. The controller is reading ~2600 in both the current and instant readings even after numerous resets.
The cell is still generating (though check cell/ salt) are still lit. I cleaned the cell at the start of the season as there was very minor build up on the sensor side of the cell. This corrected the issue for about 1 week then the low salt reading came back. I have checked twice to ensure the cell is clean.
This seems a bit on the low end for cell life (pretty much 3 years exactly). The cell is only a 3 year warranty as well per the serial number.
Again, the cell is still generating, I am just expecting failure eventually with the readings. The cell does get quite a bit of sun in Phoenix in the summer, causing a portion of the label to start to peel. Could the excessive heat cause the cell to fail early?
My plan is just to squeeze the last bit out of the cell before replacing her.
I thank you for all help in the matter. The cell has been great, I just was not expecting to run into problems at the 3 year mark! Appreciate ya'll!
