As part of our pool build, the company has someone come and clean the pool after the concrete decking is in. When they did this, the tech dumped between 2-3 jugs of liquid “shock” into the pool. Our pool is only 7855 gallons and our FC level is now 45. I’ve done the FAS/DPD test three times with the same result. Is this a good use case for chlorine neutralizer or should we just sit tight for the 10-20 days I expect it will take to burn off? Worries about damage to the liner and more importantly having a very expensive hole in the ground that I can’t use because of unsafe water.
CYA = 50
TA = 70
PH = who knows given the FC
Salt = 3000
CYA = 50
TA = 70
Salt = 3000
