Exporting data
Sam721
Active member
May 18, 2022
25
Murfreesboro, TN
I am wanting to do a bit more math on my test results to track some things. So I export the data to my computer to import in Excel. But none of my notes I put in (like change the SWG duty cycle for example) or any of the chemical additions are exported. Am I doing something wrong or is this normal? Can this functionality be added?
@Leebo has had a note for exporting chemicals and such on a list of things to keep in mind and it comes up every once in a while. One of the largest holdups we’ve ran into however is that each time we’ve been able to simply build the feature into the App thus removing the need we feel to Export. I suspect next year you’ll see roughly the same mindset as we prepare a new features for tracking your timers, SWG settings, and so forth. @Leebo can comment further...
Thanks for the insight PoolStored! I am still working on homing in on the perfect SWG duty cycles according to the weather conditions, so I am analyzing my records of FC and SWG settings from the past, but I am having to look up my SWG setting changes manually and entering them. If that becomes a feature in the future, that would be even better!
