I highly recommend borates in pools (and hot tubs). This is an excellent article describing the chemistry and benefits. Don't use the 20 Mule Team method (been there, done that) and don't pay pool store prices. Order in bulk from Duda Diesel (link in the article). Get the Taylor test strips (they use a new methodology).
Benefits of Using Borates
Borate is a buffer against pH increase so this means less calcium carbonate scaling on the hydrogen gas (H2) generation plate (negative electrode) of the SWG. That should be it’s only side effect and it is a benefit. Also, keeping 50 ppm of borate lowers the recommendation that free chlorine should be 7.5% of CYA to 5% of CYA. This is a minimum of 33% less chlorine. [Opinion]
poolchemistrytraininginstitute.com
- Keeps the pH of the water from going up (pH buffer against rises in pH)
- Helps prevent algae (it is an algaestat, not an algaecide)
- Lowers chlorine demand (preventing algae lowers the need for chlorine)
- Helps protect HOCl (hypochlorous acid – the killing form of free chlorine) from UV destruction
- Water feels softer and silkier [Opinion]
- Water looks clearer and sparkles [Opinion]
Guide to Borate for Pools • Pool Chemistry Training Institute
Borates are highly recommended for pools. Adding borate is a one-time thing. Borate does not decompose, get used up or expire. Borate is only lowered by water
