Re: Didn't learn how to build Pool's in Law School but I'm going to give it my Best!
Hi Computer Guy,
I'm trusting now you can see my pictures alas, it took a meager trial and error but I eventually figured out the magic. Anyway, I have a question for you regarding the IC60 plumbing set up. How exactly would I run two IC60 in the same system, where would I place them both? Perhaps I am thinking if I plumb separately the spa and grotto from the pool plumbing then I would run a IC60 unit there as well before it arrived at the filter.? I have searched out the internet trying to find a plumbing schematic that has two IC60 running at the same time in the same system, but to no avail. As a result any and all guidance or instruction anyone would like to share, it would be tremendously appreciated. Due to the fact that I am not a skilled a plumber by no means. all this will take some time and planning on my part. And btw Computer Guy~thank you for the warm welcome, undoubtedly appreciated.
Thank you for the encouragement! It is all very exciting!
Glock, The clay and now the added rain from last week and starting again tomorrow! It is not making this as pleasant as it could be thats for sure! However I am super excited as everyday goes by. And if you ever do go down under please let us watch!!
You are going to need a much larger SWCG unless you plan to add chlorine manually during the hottest months of the year. Even the IC60 will need to run at 100% for 18 hours a day to keep up with a pool that size. ( I hope I calculated that correctly! ) On a 3hp pump that will be costly in terms of electricity. You will also wear out the SWCG early. You might consider running two IC40's. Good luck. Can't wait to see pictures!
Hi Computer Guy,
Cool start and nice GSD (site supervisor) I have two myself.
Looking forward to more pics on the way thru the construction.
Wow, this is going to be cool to watch. I see the typical Texas clay. I think I should get my above ground taken out and get an inground installed.
