Awesome, thanks for that! I was actually trying to get them to order that for me and they charged it separately like I needed am independent controller for the SWG instead if having one work with the OMNILogic. I doubt I’ll get any money back for the over charge but I’ll add it to my case cause they were supposed to also independently plumb the skimmers back to the equipment which they did not actually do.the automation panel you actually got is the OMNIPL (HLBPLUS4W) which actually comes with 40k salt cell . these are haywards newest automation panel . I have the same and it works very well.
Is that for the OmniPL? Not sure what to do about that, we actually hate where they put the post as it just sticks out and is not covered under the side of the house. We wanted to put a fence around the pool equipment but the control panel is right in the way and we'd have to create a separate little access door. I asked if that equipment would be ok being exposed and they said it was weather proof.also i see the controller is not connected to main panel, i would highly suggest cover that connector in zip loc bag or something. you don't want it getting wet.
I think they set it up like that initially to make sure the system held pressure while the rest of the build was done. I'm expecting them to cut those pipes today and have it look like a normal skimmer.I'm curious about the pipes sticking out of the ground behind the skimmers...do you know why they are like that?
yes that's the controller for omniPL (basically a screen) . i have a 4ft fence around my equipment as well and my controller is on the side. i usually just use the app and barely use the controller.Is that for the OmniPL? Not sure what to do about that, we actually hate where they put the post as it just sticks out and is not covered under the side of the house. We wanted to put a fence around the pool equipment but the control panel is right in the way and we'd have to create a separate little access door. I asked if that equipment would be ok being exposed and they said it was weather proof.
