First, thanks to everyone here for your help and knowledge!
I have a 14 ft round ~4k gallon AGP and want to get Fafco solar on my roof. Inyopools.com says the AGP pumps they sell (ie. 1 or 1.5hp pumps) are too small to pump up to a single story roof (20 feet up) and I will need an "inground pool pump" and a pool contractor to come out and measure and spec out everything. I'm sure this is the "right" way to do it but also $$$$
Is it true some 1 or 1.5hp pumps might not be able to pump up to my roof?
I am anticipating on buying at least two 2x20 solar panels and possibly adding another one or two 2x20s later on if the first two arent enough. I am anticipating on hard plumbing ~100ft of total pipe and going up 20 vertical feet to the roof and back.
Do i need to be calculating TDF (total differential head) and the flow rates etc. of these pumps? I am hoping to get away with a 1HP pump if possibly so i dont overload my 15amp already used circuit but 1.5HP is fine.
Lastly, am I correct when saying, I need a pump strong enough to pump it up to my roof, but then this pump will be too strong to keep a slow enough flow rate for two 2x20 solar panels? It sounds like for two 2x20 solar panels at 5-7gpm each I should have a max flow of 14gpm going into the panels? How do you get your pump to hit that magic flow rate of 5-7gpm per panel for solar panels or prevent it from going too fast and damaging it?
Heres a couple of pumps/filters I am considering. I'd prefer a dual speed cartridge pump but am ok with saving alot of money for a sand filter/pump. Prefer 1HP if i can get away w/ it. Or if someone has recommendations thatd be great.
Intex 28633EG Krystal Clear Cartridge Filter Pump for Above Ground Pools, 2500 GPH Pump Flow Rate, 110-120V with GFCI, system flow rate of 1,900 gallons per hour Amazon.com : Intex 28633EG Krystal Clear Cartridge Filter Pump for Above Ground Pools, 2500 GPH Pump Flow Rate, 110-120V with GFCI, system flow rate of 1, 900 gallons per hour : Swimming Pool Water Pumps : Garden & Outdoor
Amazon.com : Hayward W3S166T1580S ProSeries Sand Filter 16 In., 1 HP System for Above-Ground Pools : Garden & Outdoor
www.amazon.com
