I have a few problems going on. My 40,000 gallon pool about 35-40 feet in length and 15 feet wide, not rectangular looks more like a "Y" shape but oval. It's losing about 1/4 inch of water over night, so even without evaporation. I have SLAM'ed it three times in the past week, and it is still green. I cleaned the filter out of all algae and this sucker was incredible hulk green the 80's version the dark green, not neon green before slamming it. I used the amount of chlorine that the pool calculator asked for one time which is 4 gallons of 10%, with cyanuric acid at 30, and added 4 bags of HTH shock. The strip was dark purple a couple of hours after I added the chlorine (yes will buy the more advanced kit), the next night the strip was white, no chlorine. I then raised the cyanuric acid to 40-50 and used 8 gallons of 10%, read somewhere to use double what the pool math calculator tells you to use, the strip has been a dark purple for a couple of days now but it lightened up a bit, and I saw the cyanuric acid is getting a little lighter. I added 3 bags of HTH schock and 9 gallons of 7% regular clorox. Today the strip continues to be dark purple on the chlorine end. For the past three days the pool color only cleared up very little on the shallow end. The deep end is so green I can't see anything past the surface of the water. It's like looking a tinted mirror it's such a deep green. I brought a pool guy, explained all this to him. He said he wants to drain it, pressure wash, and start over. What do you all think?
About the leak, I have a company coming out soon to take a look at it. I do understand that by adding water when it falls below the skimmer line that I am diluting my pool. I have not added water ever since I started the latest round of SLAMing.
