We had a raccoon poop in the pool about a month ago and we have not used the pool since then. We tried to remove the poop, but it dissolved instantly.
A majority of raccoons carry Baylisascaris procyonis, a roundworm which is not a problem for raccoons, but is extremely dangerous and often fatal in humans. Raccoons can shed millions of roundworm eggs in a single poop. These eggs can live for years, are very hearty and are not killed by chlorine or other chemicals. The only way to kill the eggs is to apply heat over roughly 140 degrees (blowtorch, steam wand, boiling water, etc.). My guess is that in Texas, concrete gets hot enough to kill them over a few days.
Here is some info about raccoon roundworm:
We are confident that this particular raccoon is infected with this roundworm and that our pool was infected. I have read the other threads on TFP regarding raccoon poop as well as all other information I could find on the internet.
The only official guidance for pools in this situation is to run the filter for 24 hours, let the filter catch all the eggs and then backwash the filter. After that, it is also suggested to drain the pool if you want to be extra careful.
The problem for me is that I have a cartridge filter and no backwash mechanism. Thus, I have no way to easily flush these eggs out. I am trying to figure out how to safely clean the cartridge filter without risking infection and infecting the area surrounding the filter. For example, when you release the filter pressure, that could release eggs right out of the release valve. Additionally, when you release the pressure before you open the filter, almost all the water in the filter drains out of the filter and back through the pump, plumbing, etc. Finally, when you remove the cartridge filters, a lot of water always spills out around the equipment. I am assuming that the eggs which are in the filter will go wherever the water goes.
We are starting to have an emergency problem because there is now major algae growing in the pool and the only way to stop it at this point is to clean and/or replace the cartridge filters. Slamming and brushing is no longer controlling it. And now there is also a fair amount of leaves and other stuff on the bottom of the pool.
This has been an absolute nightmare. Needless to say, there will be no swimming and lounging by the pool today on National Tequila Day.
Does anyone have any thoughts or recommendations on what in the world we should do and how we could safely clean the cartridge filter in this situation? Is there anyway to flush out the system in a controlled manner which would be similar to backwashing?
Thanks in advance.
Thanks in advance.
