I have an in-ground pool with an 18" elevated spa that has a spillway into the pool. To achieve independent water circulation in the spa I set the all return and drain lines to fully open. A small amount of water trickles over the spillway which I am ok with rather than potentially the spa draining while the pump is running. Once the pool pump turns off the spa water drains to the spa nozzle level. I have determined I can prevent this by closing the spa drain line (as pictured). With that said, I'm thinking a check valve installed on the drain line below the valve would solve this. If this is correct, which one should I purchase? I don't believe I have enough water head for the newer flapper type and if I go spring unsure how many pounds and would prefer an union connection type for future replacement. The pipes are 2" and I plan to switch over to a salt system in the near future (more corrosive). Thank you!
Spa Drain | Pool Drain | Pool Skimmer 1 | Pool Skimmer 2
