Got a permanant above ground pool and wanted to move the pump/filter combo and set on a concrete pad i poured. Discovered that electrical was "masked" to look like it was in conduit and was just uf cable buried under the grass after a few inches of conduit.
The whole wiring is a mess. Would like to adhere to 2014 nec code if i can. The house to shed wiring that pool power comes from, is also a mess. I just want to focus on wiring from shed then address house to shed later. So i am working backwards.
I dug a 18" deep trench for 25' from shed to pool and dug a hole to install a post to mount a single twist lock receptacle that is 6' from water's edge. I will lay sch40 1/2" pvc and run 3 12ga insulated conductors to shed. I'll also bond the motor to pool wall with #8 wire.
In the shed i would like to install smallest subpanel i can buy. I will install ground bar in box and tie ground to ground wire coming from house breaker and leave neutrals and ground isolated at panel. Install a 20A gfci breaker and run to a timer, then out to motor receptacle. I'll install one more breaker for shed light and couple outlets.
Then later i will correct uf cable from house to shed and install insulated wires in conduit.
Missing anything? Tia
