Hi Everyone, I'm new to the site and love the information and photos everyone has to share. I need a some electrical planning help...
I'm looking to install an AGP in spring 2021, perhaps with a pool installer, but want to prep some electrical now as I am putting drywall on my basement ceiling soon and won't have access come springtime.
I'm planning on a 27' diameter AGP, DE filter, an Aquatrol salt generator and a timer. Should I use 12/2 nm cable from the basement electrical panel to the timer to just outside the house? I think I then need to switch to something that is wet rated and can be in pvc conduit (attached to underside of a deck and then making its way into the ground to the filter) and make its way to the pump. Does this sound accurate? I'm questioning if I should run 12/3 as I've read a variable speed pump needs a third conductor. Any suggestions on this? Is a variable speed pump worth the extra cost?
Code calls for a general purpose outlet which can be taken from any branch circuit in the house which is good because I can tap into an existing outlet in the basement. This would be 14/2 nm from the existing outlet to just outside the house. I'm assuming I also need to then switch to lines that are wet rated and can be in pvc conduit. Can I run this general purpose line inside the same conduit as the pump line?
Final question, for today How is a salt generator tied into the electrical system, by running a third line? I've read it should only be on when the pump is on, how do you make this happen?
Thanks!
Thanks!
