How should autocover brackets with metal trays be electrically grounded or bonded?
All pools needs to be properly grounded. Since autocovers arent installed with every pool, I am going to provide some of the details of construction and masonry sitting over the brackets. The manufacturer instructions for autocovers (attached below) don't include instructions on grounding the brackets or the trays.
Autocovers covered with masonry usually are constructed using metallic brackets and sometimes metal trays sit above the brackets. The masonry sits above the tray/brackets.
Autocover box anatomy from bottom to top
1. Autocover sits in a box at one end of pool
2. Metal brackets sit above the autocover
3. A metal tray sits above the brackets (sometimes)
4. Pavers sit above the tray
Metal Brackets (usually steel, sometimes aluminum)
One metal bracket (close up)
One Tray (usually steel, sometimes aluminum - trays may vary in appearance)
Masonry sits in tray
Tray sits over brackets
Electrical Grounding Instructions for Installation of the Autocover
