- Nov 12, 2017
- 11,888
- Plaster
- Pentair Intellichlor IC-40
Mark, I'll have to defer to your expertise on the pumps. But I can say unequivocally that doubling RPM will not double a boat's speed, not even close, with the exception of certain types of hulls, like planing hulls, which, within a certain range of velocity, will lose a good deal of drag. For most other types of hulls: "A hull that is designed as strictly a displacement hull can be propelled close to its hull speed, but as the hull speed is approached the power requirement rises exponentially." This fact is what I (mistakenly or not) was applying to pool plumbing.
None of this off-topic conversation changes the following facts. Back when all a pool pump was called on to do was push water through a filter for x-hours a day, a single speed pump was all that was needed. And if that's all the OP is doing (and he can get around CA's codes), then a single speed pump might make good sense. But the point I got sidetracked making is: if the OP might want to do other things with his pump, like run a spa, a suction or pressure automated cleaner, a heater, an SWG, a waterfall, or any number of other water features, then a single speed pump would not be the best choice, not only in terms of operating cost, but also for optimizing flow rates, individually, for any of those other uses...
