- Jun 10, 2010
- 2
Hello. This is my second year with this SWG. Just now, I get code 91. Stupid me, I added more salt before testing and now it is 3300. However, the pump still states code 91. There is no build (calcium) up; however, I still cleaned it. Then I switched oultet plugs. Still get code 91.
After some research, I watched the YouTube video Watch "INTEX SALTWATER SYSTEM LOW SALT, SERVICE LIGHT FIX! SUPER EASY!!! MIKE LEE'$ LIFE HACK$" on YouTube
INTEX SALTWATER SYSTEM LOW SALT, SERVICE LIGHT FIX! SUPER EASY!!! MIKE LEE$ LIFE HACK$ - YouTube.
So I open the box to expose the circuit board. I unscrewed the two middle wires. I connected the red and white wire to the 1st (top) and the the two blacks to the bottom. I turned the unit back on and the panel still works and still gives me code 91. However, the generator seems to be making CL, by watching the eco and the cloudy mixture being released from the cell. Did I do the wiring right? After watching the guys video, I figured the panel would quit working and just produce CL after I rewired the unit. But the panel is still on and code 91 still appears, but it seems to be making CL. Going to test the CL levels tonight to compare.
I just wanted to see if anyone else with this unit had the same similar problem as I did.
Red
Red
