- Jun 16, 2019
- 119
- Plaster
- Jandy Truclear / Ei
Here’s a new one. Today I tore down my cartridge filter system and did spring cleaning on the filters. I also pulled and rinsed out the pump basket and all the skimmer baskets. I left the system idle while I cleaned the cartridges. Used the vinegar followed by dish soap approach. After reassembling everything I fired up the pump to prime the system and bleed the air from the filter egg. After that, I noticed a pile of stuff in the pump basket. Not totally out of the ordinary. So I stopped the pump and pulled the basket. Lo and behold it was a pile of earthworms….about a cup worth. Is the only explanation a busted pipe in the ground somewhere? I haven’t noticed the pool level dropping but it has an automatic filler. I’ll turn that off and see if the level drops overnight. Any other explanations or tests I should run?
