The spa is adjacent to the pool. The controls allow to run either the pool or the spa (single pump). When in the "pool" mode, there is water going over the spillway between the spa and the pump. Wehn everything is off, the spa eventually ends up with the same water level as the pool. Until recently, when the spa was running, there was a small amount of water going over the spillway. Now, not only is there no spillway flow, but the level in the spa drops about 4".
There is a bypass line between the pool discharge and the spa discharge as shown in the attached photo. There is a one way check valve and a ball valve in this line. The left side is the pool side and the check valve arrow points towards the right (spa) side. The ball valve has always been open. The check valve was replaced about 8 years ago but I can't recall the symptoms that caused it to be replaced.
The filter pressure gauge shows about 7 1/2 psi with the pool pump running. It rises to about 10 psi when the valves are switched to spa mode. I tried shutting the ball valve when the valves were in pool mode and the pressure rose to 10 psi. The volume of water going over the spillway then decreased to a very small amount but appeared to keep flowing. Closing the valve in the spa mode didn't appear to change anything.
I replaced the seals and o-rings in the two Ortega motorized valves about a year ago after I found that the valve on the suction side was leaking air around the shaft and causing bubbles in the pool discharges. The new o-rings fixed that problem.
As there are no holes in the 3 way valve rotors, I don't see how the spa was ever receiving "extra" water so that is had a slight spillover. I also don't understand the purpose of the bypass line, the check valve or the ball valve.
Perhaps someone can enlighten me as to how the system is supposed to work and why it would suddenly change.
