- Jun 7, 2017
- 9,967
- Plaster
- Jandy Aquapure 1400
Here is a good entry level drone ... it's a bit more than what you were looking for... by $5.00
Amazon.com: MJX B5W 4K Bugs 5W 4K RC Racing FPV Drone - Amazingbuy 2.4GHz 6-Axis Gyro 4K HD 5G WiFi Camera - Long Range 2420mAh Drone W/GPS, Altitude Hold, Headless Mode,One Key Return,Follow Me,Bugs GO (Black): Toys & Games
Amazon.com: MJX B5W 4K Bugs 5W 4K RC Racing FPV Drone - Amazingbuy 2.4GHz 6-Axis Gyro 4K HD 5G WiFi Camera - Long Range 2420mAh Drone W/GPS, Altitude Hold, Headless Mode,One Key Return,Follow Me,Bugs GO (Black): Toys & Gameswww.amazon.com
So you want a quadcopter? I recommend that you learn to fly first. Crashing your expensive quad or getting it stuck in a huge tree is a real possibility for a new flyer.
Once you know how to fly the sky is the limit and you can spend big $$ for all the bells and whistles.
This is a no frills unit that takes a lick'n and keep on tick'n. It is fun to learn on and even takes pics and vids. Best of all the price is right, you could buy four and stay in your budget.
Syma X5C X5C-1 New Version Explorers Quadcopter Mode 2 With Camera RC Drones from Toys Hobbies and Robot on banggood.com
Online Shopping at Banggood.com!www.banggood.com
Does it have all the newest technology, nope. It is a great learning quad and when you master this you are ready to advance.
My opinion only and yes I have first hand knowledge. Not my vid.
Thanks for that link Oly. I’ve been interested in picking one up to view my roof from the ground after storms, as well as wanting to learn how to fly one.So you want a quadcopter? I recommend that you learn to fly first. Crashing your expensive quad or getting it stuck in a huge tree is a real possibility for a new flyer.
Gain the intuition of a forward perspective even when the quad is rotated.
The less expensive camera drones do not have a display...so you do not get the perspective of flying as if you were in the cockpit...you fly by sight from the ground. If the drone were flying away from you and then it turned around and headed towards you the controls would seem to work backwards...this takes practice to learn.
Headless drone
When you active headless mode, the onboard flight computer always aligns the drone movements to be relative to the controller. So it does not matter which way the drone forward direction is pointing. When you push forward, the drone moves forward relative to your direction, not the heading of the drone.
If you take the camera off, how do you know which way is forward?![]()
Actually the description specifically addresses this. It uses the phone for real time display (FPV) and the controls work in "headless" mode.
Brushless GPS Drone with Camera D80 White | GPS Drones | Potensic
D80 GPS drone flies safely, steadily and with maximum stability at a fixed height of your choosing, leaving you to snap the perfect picture. Brushless Motors are more powerful, durable and with low consumption.www.ipotensic.com
The display and headless mode are good features to have. Oly's comment to remove the camera is to prevent damage when learning to fly. Many crashes will be had while learning to fly so removing the camera saves that component from damage. One also needs to learn to fly by sight from the ground. Wireless signals can drop, leaving only minimal control of the drone.
